Unexpected behavior of input()
5 months 1 day ago - 5 months 1 day ago #112
Unexpected behavior of input() was created by ludojoey
Here are a few lines of code:
When running this small program, after a few executions (1, 2, 3, 4...), the "input()" function no longer waits for character input and behaves as if the Enter key had been pressed immediately.
When this happens, after returning to the OS, the next character typed is duplicated. For example, if you type A then AA is displayed.
If I remove the memSet() line, the issue no longer seems to occur.
Version 0.7.7 used.
memSet(0x3000,48000,0,0x60);//clear bitmap.
text t={3};
print("Type something:");
input(t,3);
Version 0.7.7 used.
Last edit: 5 months 1 day ago by ludojoey.
5 months 13 hours ago - 5 months 13 hours ago #117
Replied by Franck on topic Unexpected behavior of input()
There seems to be a strange bug indeed when something is already in the text display buffer on the same line as the input line.
I need to investigate. I'll get back to you when I find the problem.
Last edit: 5 months 13 hours ago by Franck.
4 months 4 weeks ago #119
Found the bug. Not related to input buffer line as stated above.
It was the autorepeat timer that would re-trigger an Enter keypress if by any bad luck the first Enter was press a fraction of second before the timer interrupt was fired-up and the release of the key before the input() function execution in the VM, effectively registering two key presses. The memSet() function takes a bit of time and was allowing this to happen more often.
Fixed in 0.7.8
Fixed in 0.7.8
Time to create page: 0.152 seconds
