- Thank you received: 1
Bug text/print/compile
4 months 4 weeks ago #121
by PAGIR
Bug text/print/compile was created by PAGIR
Hello, I got this problem (using version 0.7.7)
1) I created this small LOFI program (text_bug.src):
text t1={10};text t2="Hello World";
print("t2=",t2,"<enter symbol>");
text t3={20};
=> compilation+execution OK
2) I remove both " embracing <enter symbol>
I save program
compilation failed (OK); Error in 2 Expect expression .
3) I add again the 2 ", save the program and compile under text editor
Result: I still get error message (not OK)
Retry and retry: still KO
I exit text editor and come back+compile, still same problem (compilation KO)
4) I exit text editor
I try a CLI command: compile text_bug.src
I get compile error
Error in 2, at ','. undefined variable.
I retry the same command AND NOW it is successful !
text t3={20};
I save program
I get compile error
4 months 4 weeks ago - 4 months 4 weeks ago #122
Replied by Franck on topic Bug text/print/compile
It is a compiler (re)initialization issue. For some reason, it misses the first line when recompiling after the compile error and thus misses the t2 declaration.
If you reset the computer or simply add a new empty line before line 1 it works again.
Working on it ! Thanks for noticing.
Edit: Found the issue, the parser was not reinitialized properly after a compile error. Fixed in 0.7.8
Last edit: 4 months 4 weeks ago by Franck.
Time to create page: 0.157 seconds
