Possible code generation bug involving arrays and struct fields
4 months 2 weeks ago - 4 months 2 weeks ago #155
Hello!
Attached to this message (`mr.src`) is an excerpt from a game I'm currently trying to develop.
I've attempted to strip the code down as much as possible in order to keep only the smallest portion that still reproduces the bug. As a result, what the code does may seem a bit silly, but that's expected.
Ver 0.7.7 is used.
In summary:
* There is an array of 4 variables of type `tweapon`.
* This type contains, among other things, the variables `X` and `Y`.
Initially, for all 4 elements, `X` is set to 250 and `Y` is set to 200.
Then, for each element, `X` is incremented by 1.
If it reaches 548, it is reset to 0.
The process then repeats (resetting `X` and `Y` to 250 and 200, respectively, and so on).
The issue is that the value of `Y` does not remain at 200 for the second element (index 1), but is et to -2360.
If I remove line 46:
weapon.yOfs = weapontype[j].yOfs;
the problem no longer occurs.
In addition, in my original project (although not in this reduced example), I am forced to use an intermediate variable (line 42); otherwise, the code does not compile.(or if so, the program will not act as expected).
But this is maybe the bug you already correct in the next version.
I hope this helps track down the issue.
Ver 0.7.7 is used.
In summary:
Last edit: 4 months 2 weeks ago by ludojoey.
4 months 2 weeks ago #156
Replied by Franck on topic Possible code generation bug involving arrays and struct fields
It seems to work fine on my version so I suspect this is related to the same previous bug that I fixed recently.
I'll try to have the 0.7.8 released this w.e.
PS: I reverted to 0.7.7 to test and indeed the problem was happening in that version but no longer in the upcoming one.
Time to create page: 0.174 seconds
