Sprited max sprites
4 months 2 weeks ago #159
Sprited max sprites was created by ludojoey
Thanks for the new version 0.7.8
Just a question :
SPRITED is limited in the UI to 19 sprites.
I see in the source code , in your comments, that it should be 55.
However, the var "end" on line 55 has a value of 19.
If I change this value to 55, it seems that I can edit 55 sprites (instead of 19)
Is it sufficient to change the "end" var to edit to 55 spirtes with SPRITED ?
Thanks!
Just a question :
Thanks!
4 months 2 weeks ago - 4 months 2 weeks ago #160
Replied by Franck on topic Sprited max sprites
The end variable is indeed the default ending of the current edited set. You can increase it. You can also increase/decrease from the UI by adding/removing sprites.
The sprite editor was initially developped on a prototype board that only had 128 KiB of RAM. Hence the limitation to 56 (0-55) sprites. I need to update the code so that it can work with the full 256 sprite set but I did not have time to do so for this release.
Meanwhile if you need more sprites, you can load multiple smaller sets in your application.
Last edit: 4 months 2 weeks ago by Franck.
4 months 2 weeks ago #161
Replied by ludojoey on topic Sprited max sprites
Thanks!
55 sprites is more than enough!
Time to create page: 0.171 seconds
