Array of custom type variable / Passing by ref a custom type variable
4 months 1 week ago - 4 months 1 week ago #173 by ludojoey
Hello!
I try to pass an array of custom type variable as a function parameter:
type myType {
   int a;
   int b;
void f(myType t) {
   t[0].a=1;
At compilation I get the error "Expect ) after [optional] params" on the line of function declaration.
In fact, at start, I wanted to pass a custom type variable by reference.
As it seems it is not possible, my "solution" was I could pass it as an array (as arrays are passed by reference) and then access it by the index "0".
Last edit: 4 months 1 week ago by ludojoey.
4 months 1 week ago #174 by Franck
Yep, passing an array of custom type as arg to function is not yet supported. It's in my todo list :)
To simulate passing custom types by ref, you can pass the address of the custom type to the function as a nat, and peek/poke or peekw/pokew (depending on the member type) at address+member offset by hand in the function. Not ideal but it should work (I did not test it yet).
4 months 1 week ago #175 by ludojoey
Thanks for your reply!
Yes, I thought to do this, but not very readable..
Well, I will use an array of global variable and will pass the index to work with.
Time to create page: 0.178 seconds
