loading BMP in Micro-8
1 year 3 weeks ago - 1 year 3 weeks ago #23 by David
loading BMP in Micro-8 was created by David
Here is a routine to read a BMP image directly on the Micro-8. Make sure the BMP file is max 16 colors, max 400x240 resolution.
Here is how to convert the image in the correct BMP format using GIMP.
  • Open the image in GIMP.
  • Go to Image → Mode → Indexed...
    • Set Maximum number of colors to 16.
    • (Optional) Enable Color dithering for smoother gradients.
  • Adjust the image size if needed:
    • The Micro-8 loading routine supports images up to 400×240 pixels.
    • If your image is larger than this, use Image → Scale Image... to reduce it to 400×240 or smaller before exporting.
    • When exporting, check “Ignore alpha channel”.
    • Make sure RLE compression is unchecked.
    • Then click Export.
This attachment is hidden for guests.
Please log in or register to see it.
Last edit: 1 year 3 weeks ago by David.
1 year 3 weeks ago #24 by Franck
Replied by Franck on topic loading BMP in Micro-8
Awesome, thanks @David.
Just to clarify, this routine will load the PC Image format known as BMP into the bitmap memory. Not to be mistaken with Micro-8's native BMP (bitmap) files produced by the Image Editor.
1 year 2 days ago #46 by David
Replied by David on topic loading BMP in Micro-8
Update 0.9 :
- fix in loading picture
- better palette conversion
The following user(s) said Thank You: Franck, ludojoey
4 months 4 weeks ago - 4 months 4 weeks ago #118 by ludojoey
Replied by ludojoey on topic loading BMP in Micro-8
Here is a modified version that prompts the user for the name of the BMP file to convert (Windows BMP, 16 colors, 400×240), and then converts it to the Micro-8 format, generating CONVERT.BMP and CONVERT.PAL.Tip: To convert an image to a 16-color BMP file, you can use the online converter available here: online-converting.com/image/convert2bmp/
Last edit: 4 months 4 weeks ago by ludojoey.
The following user(s) said Thank You: Franck, David
Time to create page: 0.185 seconds
