How to convert existing map to Micro-8 ?
1 year 2 weeks ago - 1 year 2 weeks ago #37 by David
A short tutorial to help you easily import an existing map for the Micro-8.
A great resource for maps is vgmaps.de/maps/ .Simply search for the map you want and save the image — for example, the Alex Kidd map.
Next, load this map into portabledev.com/pvsneslib/tilesetextractor/  (make sure to convert it to PNG format first).Choose the tile size (16×16). The site will automatically detect all the tiles and generate both a tileset and a tilemap.  Double check to not exceed 256 tiles in total.
Then, just click “Download tiles.png” to save the tileset, and “Download map.json” to save the tilemap.
After that, you’ll need to convert tiles.png to BMP (PC format) so it can be loaded directly into the Micro-8 Tile Editor.
The json file can be converted to a raw file (each entry = 1 byte). Soon, the Micro-8 Tile Editor will be able to import JSON files directly.
Last edit: 1 year 2 weeks ago by David.
The following user(s) said Thank You: Lenko, garrettx
Time to create page: 0.162 seconds
