Release of Tilemap Editor 1.0 – Testing Phase
1 year 3 weeks ago - 1 year 3 weeks ago #20 by David
The Tilemap Editor 1.0 is finally available! This tool lets you easily design your own tilemaps, import tilesets, manage multiple layers, and save your creations effortlessly.
Main Features:
-Create and edit tilemaps of any size (minimum 25×15 tiles, max 15kb).
-Up to 8 layers available for paths, collisions, or any custom data.
- Simple drawing tools: selection, copy, erase, random mode, etc.
This release is still in testing, so you may encounter a few bugs or unexpected behaviors.
Please don’t hesitate to report bugs, suggestions, or ideas for improvement here on the forum — your feedback will help refine the editor for the final release!
A complete PDF manual is included, explaining every feature, option, and shortcut in detail.
A simple example is included. Just load the three test files: TEST ( tileset ) , TEST ( tilemap ) , and TEST.(layer )
They’ll give you a quick idea of how the editor works and how tiles, maps, and layers interact.
Have fun creating your maps!
This attachment is hidden for guests.
Please log in or register to see it.
Last edit: 1 year 3 weeks ago by David.
1 year 3 weeks ago #25 by David
V 1.1  Available :
some bugs fixed
new functions and shortcuts :
• GENERATE PATH LAYER
Transform the active tiles into a path on the active layer
• INVERT LAYER
Invert the layer state
• CLEAR CURRENT SCREEN ( tiles & layer mode )
1 year 2 weeks ago - 1 year 2 weeks ago #32 by David
V 1.2  Available !
Simplification of the file format :  the palette and tileset are now contained in a single file, as well as the layer and its dimensions, and the tilemap and its dimensions.
Also added is a small example library ( EXAMPLE.SRC ) that allows you to quickly integrate map scrolling and tilemap/tileset loading into your projects.
2 examples in the archive: DEMO.LVL + DEMO.TLS + DEMO.LAY  and DEMO2.LVL + DEMO2.TLS
Last edit: 1 year 2 weeks ago by David.
1 week 8 hours ago #303 by ludojoey
I just made a small modification so that the program also accepts .TLS files whose color palette isn't embedded in the file, but is stored in a separate .PAL file.
I actually ran into this little issue myself!
Basically, if the file size is not 32816 bytes, we assume that the palette is stored separately.
If you're happy with this change, perhaps you could release it as version 1.3? It's entirely up to you!
Time to create page: 0.218 seconds
